Hello,
I've got a SketchUp model that I've referenced into DataCAD. I'm trying to generate a plan view, but the model is showing up as transparent, so I'm seeing every line from the model instead of just a top down plan view. Does DataCad have the ability to create a section cut at 4' and generate a live view of that, or is the only way to generate a snapshot of the view through the hidden line removal tool?
Thanks for any help.
