Our office staff has been experiencing Datacad crashes. Has anyone else had this problem and if so were you able to correct it?
When is it crashing - opening a file, saving a file, inserting a symbol, trying to access an xref, or ...?
Highest Regards,
Alan T. Hendry, RA
Alan T. Hendry, RA
It is not any particular thing. Mostly when I am trying to do something with xref clip cubes, moving symbols, etc. I keep getting the note fault 11 error 809.
Seems to be a big issue once you have multiple xreferences in the drawing.
Hi Gary,
I get this with the xrefs and it can waste hours rebuilding the drawing file.. The big problem I've found is once a file begins to crash it corrupts the xref layer. If you save a DLF of each xref layer and check the file size they should be around 8kb - 24 kb. I've found once a drawing with xrefs keeps crashing, not only does the drawing file size start to increase but it also takes longer to save, display etc. The only fix I've found is to use the Repair Tool first to remove any unwanted entities, odd z-b/z-h etc. then reload the xref layer by going back to a file before the crashes started to occur, saving out the DLF of the xref layer(s) and replacing the ones in the current file and purging to create a new file. I had a corrupt xref layer yesterday that was about 135MB yet once I went back to an earlier file the same xref layer was back to 8KB and loaded straight away. Other problem areas are exiting MSP or opening an MSP sheet with a problematic xref in - the drawing crashes immediately or the error you note below.
DataCAD user since v4!
Regards
Mark Bell
Principal
ATELIER MARK BELL
Australia
Regards
Mark Bell
Principal
ATELIER MARK BELL
Australia
What is the repair tool? This is something I am not aware of.
Hello Gary,
Prior to opening a drawing, go to the top left of the DataCAD screen and pick File then Repair should be shown in the drop down menu. Pick the drawing file you're working on when the menu window opens then follow the prompts. I'd toggle off Flatten 2D entities as your drawing may use entities at different z-b/z-h within clipcubes and this will lost. It also allows you to open the drawing without loading the xrefs as a way of getting into the drawing if an xref is causing it to crash on opening. It's a useful tool and can also be used to 'cleanup' symbols which may also have corrupt entities in them.
Regards
Mark Bell
Principal
ATELIER MARK BELL
Australia
Regards
Mark Bell
Principal
ATELIER MARK BELL
Australia
See my post under "How Do I Stop Files Containing XRefs From Crashing" in the How To sub forum for another cause of a XRef crash.
Users browsing this forum: No registered users and 105 guests
