#78874 by Gary24752
Tue Oct 06, 2020 11:17 am
Is there a way when doing a drawing to avoid getting 1/32" or 1/16" dimensions? I have set my grid to 1/8" and the origin on a corner of whatever I am drawing. Is this an Idiosyncrasy of the software, computer age, mouse, drive, etc. or is there a setting to correct this?
#78877 by Roger D
Tue Oct 06, 2020 1:24 pm
In the Dimension menu, you can set your rounding precision
Dimensions/Dim. Style/Rounding/Precision
#78900 by Gary24752
Sat Oct 10, 2020 10:30 pm
I don't use rounding as it just compounds into a lot of little issues thru the drawing. I suspect that the culprit may be the snap to the nearest point being turned on may be the culprit in the course of creating the drawing. I was just curious as to whether different computers, mice, age of hard drives may have on it. I tried setting the snapping grid to 1/8" but it did not seem to make a difference.
#78916 by Ted B
Wed Oct 14, 2020 2:51 am
I'd just like if "rounding" had a higher limit. For large-scale drawing and sitework I need rounding in inches or even feet in associative dimensions. Paticularly in conceptual drawings. IIRC the upper limit is 1/8th or 1/16th-inch now?
#78917 by joshhuggins
Wed Oct 14, 2020 1:25 pm
#78920 by joshhuggins
Wed Oct 14, 2020 6:40 pm
Opps Neil is right, we can set it at the drawing level to whatever we like. I have mine at 1/16". What I would like is a when using Unit Lock, with Arch, being able to set rounding to levels other than 32nd - 256ths.
#78969 by Gary24752
Thu Oct 29, 2020 10:52 am
Using rounding for me is not an option. I have found especially with structures with steel rounded dimensions can lead to mistakes from one end of the building to the other especially with odd plans. I figured out that I need to set my grid to the minimum of 1/8" and set the origin/reference on one corner of the structure. Thank you for all your replies.
#78980 by MtnArch
Fri Oct 30, 2020 9:41 am
I've found this happens even when you type in the dimensions and angle (which I always do). I've reported it to Tech Support but no one has been able to figure out where it comes from or when it happens. It's very frustrating!
#79007 by artmanvt2000
Wed Nov 04, 2020 3:41 pm
I never use rounding. I have found errors with the accumulative dimension adding up to more than the overall dimension. I usually only dimension to 1/8", but when doing commercial buildings with 3 5/8" metal studs, you will sometimes get a 1/16" dimension.
I also spend the time to stretch the drawing to the required dimensions. This can also avoid conflicts down the road. Just like I never manually change the dimension.
Users browsing this forum: No registered users and 68 guests
