#79387 by The Canuck
Fri Feb 26, 2021 11:53 am
I know this has been brought up before . But I want to bring it to the surface again today. I had to print a few sets with many pages, and it stinks that if I need (4) sets, it will print each page 4 times, before moving on to the next page when doing batch printing.
I understand that you can print to PDF and that would allow you to then merge the PDF into one. But I have never found the PDF's to carry the line weights like I would want them to. (I am using version 20 of DataCAD and using Adobe for the PDF's and merging). Maybe its a setting I am not doing correctly. Either way, I would prefer not to have to add in the extra couple steps if I don't have to. I saw version 22 allows for the PDF, but not having tested it out, I don't know if the line weights are carrying through as accurately as when I print. If someone can show me, that would be great.
I think.... no, I know, I would buy the next version of DataCAD that has this feature, just for the feature. Guarantee it will pay for itself within a month or two of not having to rearrange all the sheets.
#79403 by Dave
Wed Mar 03, 2021 1:35 pm
#79408 by The Canuck
Thu Mar 04, 2021 8:33 am
The same settings that I use to print. I will batch print a set to my HP Printer (DesignJet T520), then also batch print a set to the "print to file". I would think the settings would be the same no?
#79412 by Dave
Thu Mar 04, 2021 9:31 pm
A sample of PDFing from DataCad
Left most was with Microsoft PDF set as printer but doing a SaveAs from the Plot Menu, the rest are all plots
Line weights 1 to 10
When I look at them on my screen the rightmost 2 appear the best. I don't have a high dpi printer with me to check them once printed.
These were viewed in PDF-Xchange and I took a screen shot
I think there is a setting in Datacad to change the SaveAs DPI
DataCad 18, default pen table
DaveR
#79413 by The Canuck
Thu Mar 04, 2021 9:40 pm
Thanks Dave... I might need to look into that some more.
What stands out the most for me, is if I create a PDF set, and then go to print it, everything appears to be the same line weight. So it might be more the settings within Adobe that I am using and have not adjusted it. But I would think the line weights would transfer to the PDF, and then to the print of the PDF.
But as I said in my original post, if a collate feature was added to the next version, I would jump on it. Saves me a few steps with converting and combining PDF sets, and then printing. Which of course, saves time/money. :)
#79415 by Dave
Fri Mar 05, 2021 5:17 am
Users browsing this forum: No registered users and 121 guests
