Utility/Geometry/Offset
or from the edit toolbar.
I've added an extra icon to my edit toolbar for offset fixed distance, when clicked it asks for the offset distance, hit enter to accept whats already there or enter a new distance.
In the support Files\Toolbars\Edit.dtb under the existing OFFSET entry I added
[OFFSETFD]
Hint=Offset (Fixed Distance) - Copy entities parallel to existing entities
Icon=DTB_OffsetFD
A=^:^F6^F3^Ã^F1^F2^F2
"Life isn't about dawdling to the grave, arriving safely in an attractive, wrinkle free body, but rather an adventure that ends skidding in sideways, champagne in one hand, strawberries in the other, totally worn out, screaming 'yeehaaa, what a ride!"
Another way to get quick access to the Offset function is to edit your DcadWin.mcr file (that is in the DataCAD/Support Files folder). Here is my Alt-O keyboard shortcut:
You can Copy and Paste this into your DcadWin.mcr file in place of the O (or another letter if you want - but change the O at the beginning with the letter of your choice).
Code: Select all
O^Ä^20#^F3^F2^F2
//Perpendicular Offset\Distance
Dave likes this
Thanks. I had not used datacad for 2 years. I finally found it myself.
Users browsing this forum: No registered users and 22 guests
