#80091 by Roger D
Tue Sep 14, 2021 1:50 pm
There is a delete double command under the 3dMenu, Hide, Options. Then run the hide command on the area. Should work.
#80094 by Joe Krawiec
Wed Sep 15, 2021 8:13 am
Hi,
I have often wondered about this. At times, I simply go through and delete the line, refresh, repeat. Annoying at best. I just tried using the delete double command, but it doesn't seem to work.
Joe
#80209 by Roger D
Fri Oct 01, 2021 8:03 am
Did you have "Save Image" selected and saved to a new layer.
If that didn't work, then the lines must not be exactly the same.
#80211 by Joseph Baron
Fri Oct 01, 2021 11:12 am
Hide does work to remove duplicated lines, using Save Image as Roger pointed out.
I used these settings, in Options with F2 Delete Dbl. & F3 Ignore Color, and Hide F3 Save Image & S5 Active ON, you can get a new layer with duplicated lines removed, and even shorter lines with the same or different Z settings under longer lines get removed.
Users browsing this forum: Lane and 143 guests
