does anyone have people templets that are just the outline and are filled in?
Skipp, you've probably already found sites like https://acad-block.com/people-cad-block ... side-view/ where you can download and make the DataCAD symbols that you need. Hope this helps.
DataCAD 22.02.14.02 BETA on my own build Gigabyte MOBO rack mounted Windows 10 Pro 22H2 x64 i7 920
Thank you - now i have to discover how to load the template into my dataCAD program. I see it is in dwg format for autoCAD.
Can you tell me how to convert it to dataCAD symbol file?
Skipp wrote: Can you tell me how to convert it to dataCAD symbol file?
Import the DWG into DataCAD, modify your drawing as needed, CTRL+T to open the Symbol Browser, then use Save Symbol.
joshhuggins likes this
They import into DataCAD as Drawing symbols:
There is a macro SYMTMPLT that will write out symbols from a file to a template, putting them into a directory that you select.
Users browsing this forum: No registered users and 83 guests
