How do I fill around an ellipse?
I found an answer to filling inside an ellipse. What about omitting the ellipse?
Thanks.
Steve
Thanks.
Steve
Neil Blanchard wrote:Hi Steve,
You can do a void for many shapes, in the middle of a hatch or fill. You need to do it manually, with the 4 arcs method.
With a little practice, you can use 3-Point arcs to do the R1 and R2 arcs illustrated above.
Mark Bell wrote:Try drawing a rectangle or other shape around the ellipse then hatching the area on the outside of the ellipse and inside of the rectangle.
Users browsing this forum: Google [Bot] and 19 guests
