If you could post what the message says and a description of what you were doing at the time, might be able to help a bit more.
photo of error
Sandra Mashburn
Sandra Mashburn Home Design
Ellijay, GA
Ellijay, GA
I pulled up the drawing file to print and got this error.
Sandra Mashburn
Ellijay, GA
Ellijay, GA
Not sure about that specific error, but since you said it happens while trying to print maybe try these things.
Try these out, it it doesn't work and you have a Subscription License, you could send the file into Datacad for deeper analysis.
- Open the drawing and first thing hit CTRL+SHIFT+C. This should reset the printer settings for the file. Save and close the file and then re-open to try to print.
- With no files open, go up to File, Repair, leave the defaults and click OK on the first pop-up and then click OK on any messages saying errors were found. Then finally click on the Z-base/Height dialog, if any abnormal entities are listed in the bottom table, click the Flatten button, then click Close. This is a quick tool to hopefully clear any funky entities in the file.
- You could also create a new blank file and then use File, Import and try to import your working file into it. This process should recreate all the entities and views during the import process. I would Save As to a temporary file name first, close the file, then re-open the file and see it will print then. If everything looks like it's working good, you could Save As back to the original file name.
Thank you! Importing the file into a new drawing worked.
joshhuggins likes this
Sandra Mashburn
Ellijay, GA
Ellijay, GA
Users browsing this forum: No registered users and 124 guests
