I'm working on an L-shaped plan, but the two legs of the plan are not at 90-degrees from each other.
So, the one leg is not square (it's actually at 92.969-degrees).
Is it possible to toggle between the standard angle and an alternate angle, so I can draw with straight lines and not offset every line?
Joined
Fri Mar 11, 2022 8:49 am
Try using Geometry > Tangents to align the snap gird to the existing line.
Joined
Mon Feb 14, 2005 8:03 am
Location
Nashville, Tennessee
Here's a keyboard macro that allows you to select the line to set tangent to, then run again to reset to 0. Ortho should be ON.
^:^f6^f4^f3^$^
Joined
Location
CDAVIS, did this work for you?
Joined
Location
Users browsing this forum: Google [Bot] and 8 guests
