Continuing my deep dive into all that is DataCAD 3D one thing that would be very helpful is to be able to 'Save Image' for the selected Shape that is in Construction Plane, or in the 'FLAT'.
Being able to model constructs then get that shape in the 'FLAT' to create fabrication drawings & dimensions would be very beneficial. There may be already a macro somewhere to do this but seeing that you can do a hidden line view then save image it looks like all the 'tools' are there to do it, but do it for the isolated / selected shape or even all the shapes that are in the same construction plane.
This example is a roof model showing CTRL+right-click menu which could be a good place to add 'Save Shape Image'.
DataCAD 22.02.14.02 BETA on my own build Gigabyte MOBO rack mounted Windows 10 Pro 22H2 x64 i7 920
