Biggest crash ever!
I hadn't used Clipit in a while and forgot how Datacad becomes unstable when using it.
So I copied a cross section of my current project, then invoked Clipit to save a portion of the drawing for enlarging as a detail. My first keystroke was E to erase a line I didn't need---and DC crashed. So I opened the most recent Autosave, recreated my work of the past ten minutes and redid the Clipit function, saving with Ctrl-S after each keystroke.
Like a dummy, I saved the drawing immediately after using Clipit (using Save, not Save As)
When I zoomed out, I discovered that I had clipped out all my other work.
Now I can't recover anything except what you see in the attached DC21 file.
My last Save As was two days ago.
Is there any way to recreate my work up to the crash? I promise never to use Clipit again......
joe
joe
(2.04 MiB) Downloaded 337 times
