Is there a way to get a color palette for datacad 21 that will match the photos on my iphone?
You can use the Eye Dropper that was added to DataCAD 21.03.08 Subscription. Otherwise, you'll have to use a third-party paint program to grab the rgb values and manually add them to the DataCAD color palette.
I have no idea what the Eyedropper is that you mentioned. Where can I read about it?
- From the Help pull-down menu select Revision History.
- In the PDF viewer, search for the term 'Eye Dropper'.
It's also covered in the 'What's New in DataCAD 22?' document.
Users browsing this forum: No registered users and 15 guests
