Use this forum to ask questions about DataCAD 23 and DataCAD LT 23.
#82786 by Totarakid
Thu Feb 15, 2024 11:49 am
Whenever I save a drawing as a new file name i.e. 2213-102 being saved as 2213-103, the following error message always appears:
Unable to open file, file decompression error: 101
DCad error.JPG (13.1 KiB) Viewed 6318 times
#82789 by DBrennfoerder
Fri Feb 16, 2024 12:49 pm
Are you opening a file that is on a CD and DataCAD can't put the background files on it?
#82797 by Totarakid
Tue Feb 20, 2024 8:23 am
Thanks for comments guys.
not using a CD. Being saved into Dropbox folder on PC .
Not heard of Purge menu. will have to investigate that one.
#82798 by Mark F. Madura
Tue Feb 20, 2024 9:30 am
Are you running 23.00.01?
The error you're getting occurs when DataCAD is trying to open the 'Saved As' file (i.e. uncompress the AEC to a $WP file). Are you 'Saving As' to a different folder than where the current drawing is located? If you open the destination folder in a file explorer window, does SavedAs.aec get written to that location? Error 101 means DataCAD was unable to open SavedAs.aec.
MFM
#82800 by MtnArch
Tue Feb 20, 2024 10:56 am
Jim Goodman had a specific way to set up and save to Dropbox for remote users to access files from one central location. At the moment I don't recall how he did it, but it was something you had to set up very carefully.
