#952 by KIWIGULL05
Sun Mar 13, 2005 10:09 pm
Hi
I must be getting old because I can't remember how to draw voids in slabs
I have drawn the primary slab and done as the manual says but I get "0 entities selected" when trying to apply the void. Can somebody help this old feller!!
Mike :?:
#953 by Graeme
Mon Mar 14, 2005 1:48 am
To apply a void to a slab you need to make another slab in the position you want the void. Making sure the smaller slab is the same thickness as the main slab & at the same height in elevation. Then click "voids" in the slab menu, click the main slab first then the smaller slab (the one the size and position of your void). Then right click out... You should have it
Hope you manage to figure it out, if not maybe I can explain a little different. Good Luck.
#955 by KIWIGULL05
Mon Mar 14, 2005 4:02 am
Hi Graeme
Thanks for your response-I have it sussed again. I must learn to read the manual properly-Glad you guys are out there!!
Mike :P
Users browsing this forum: No registered users and 67 guests
