I haven't been able to open the free arrow macro. Anyone else having this problem?
It didn't seem to do anything here too.
Thanks! - Josh
Worked okay for me on my boxes.
Highest Regards,
Alan T. Hendry, RA
Alan T. Hendry, RA
I'm not sure why that happened, but I wasn't able to open the files either. Thank goodness, I had the original so I just use that.
If you want the macro, send an email to me directly at orwoody@gmail.com and I'll be happy to send both of those files to you.
Woody
Woody
This is the first time that I've tried to attach a file to one of these messages.
If you download successfully or unsuccessfully, let me know.
I would like to know if there is any interest in this or if I just created a macro that has no useful purpose.
The macro is just for creating several different styles with heads at each end. They are dumb lines so can be modified easily.
For example: If you use the dots arrow to create a site layout, while still in the macro, use the comma to erase the dots as needed to prevent having two congruent dots at each corner point. The way to do it would be to create the first line.
Create the second line and immediately touch the comma twice. Create the third line. Create the fourth line and immediately touch the comma twice.... Continue touching the comma twice after each even numbered line. When you've completed the site (assuming no curves), you have a clean property boundary with circles at each corner point.
Downloaded ok here haven't tried running the macro yet.
DaveR
DaveR
"Life isn't about dawdling to the grave, arriving safely in an attractive, wrinkle free body, but rather an adventure that ends skidding in sideways, champagne in one hand, strawberries in the other, totally worn out, screaming 'yeehaaa, what a ride!"
Works on my box, too. Win7 DataCAD 20.02.03.05
This one worked, thanks dude! Will play with in a bit!
Thanks! - Josh
