#78874 by Gary24752
Tue Oct 06, 2020 11:17 am
Is there a way when doing a drawing to avoid getting 1/32" or 1/16" dimensions? I have set my grid to 1/8" and the origin on a corner of whatever I am drawing. Is this an Idiosyncrasy of the software, computer age, mouse, drive, etc. or is there a setting to correct this?
#78877 by Roger D
Tue Oct 06, 2020 1:24 pm
In the Dimension menu, you can set your rounding precision
Dimensions/Dim. Style/Rounding/Precision
#78900 by Gary24752
Sat Oct 10, 2020 10:30 pm
I don't use rounding as it just compounds into a lot of little issues thru the drawing. I suspect that the culprit may be the snap to the nearest point being turned on may be the culprit in the course of creating the drawing. I was just curious as to whether different computers, mice, age of hard drives may have on it. I tried setting the snapping grid to 1/8" but it did not seem to make a difference.
#78916 by Ted B
Wed Oct 14, 2020 2:51 am
I'd just like if "rounding" had a higher limit. For large-scale drawing and sitework I need rounding in inches or even feet in associative dimensions. Paticularly in conceptual drawings. IIRC the upper limit is 1/8th or 1/16th-inch now?
#78917 by joshhuggins
Wed Oct 14, 2020 1:25 pm
Ted B wrote:I'd just like if "rounding" had a higher limit. For large-scale drawing and sitework I need rounding in inches or even feet in associative dimensions. Paticularly in conceptual drawings. IIRC the upper limit is 1/8th or 1/16th-inch now?
Yes, this would be really helpful!
