#80087 by James Walter Schildroth
Tue Sep 14, 2021 10:02 am
I want to make a 24 x36 size sheet copy to send to a printing service. I only have a 8 1/2 x 11 size print connected to my laptop. When I go to print the only sizes available are for that printer. I want to send a PDF to a printing service. How can I do this? Please reply by e-mail james@schildrotharchitect.com Thanks, James
#80089 by MtnArch
Tue Sep 14, 2021 12:57 pm
Either edit the PDF writer you have (Adobe, PDFill, CutePDF, etc.) to add a custom 24x36 sheet, or install a plotter driver (such as a Canon iPF785 or an HP DesignJet) even though you don't have the plotter. All you really need is the definition of the plotted paper size. If you install a plotter driver you will likely also gain other sizes (18x24, 30x42, etc.).
#80090 by Roger D
Tue Sep 14, 2021 1:43 pm
I use the free version of bullzip, it can print to a variety of file types
BMP, JPEG, PCX, PDF, PNG, and TIFF
PDF-Exchange is also a good one, it has editing tools also
and or
PDF Fill which also has tools to split, reorder, merge pdf files.
#80095 by MtnArch
Wed Sep 15, 2021 9:21 am
Just for grins 'n giggles, I downloaded the plotter driver for an HP T650 large format printer (https://support.hp.com/us-en/drivers/se ... s/38030054) though you could do it with a Canon plotter, Epson plotter, etc. Followed the prompts and when it said it couldn't find the plotter there was an option to pick "To File", and I selected the T650 36".
I was given the opportunity to pick the "Easy" installation or "Custom" - I chose Custom so there's less HP bloatware for me to remove after the installation (I have a Canon iPF plotter and don't need the HP .. just following it through for this example). The software finished installing & I checked to make sure it was installed under Windoze Printers (yup .. it shows up).
I fired up DC V22, opened a file, and then told it to print. Selected the T650 and set it to an Arch D size, and was able to save out the PDF at 24x36.
Hope this helps!
