I have a HP220 design jet that plots a max. 24"X36" sheet. I have a drawing that will only fit to 30"X42". I need to save it to a .plt file at this size to e-mail to my printer. But, because it exceeds the limits of my printer it will not let me save it at 30"X42" size. Is there a way around this? Thanks!
Hello:
You can install the driver for the plotter that the service uses -- and set the port "To File". That way you're sure to have the right paper size. Or, you can install a "generic" driver like the HP 750C and do the same sort of set up.
