MFM> 15. You can now write a macro to select a custom color (16 to 255).
MFM>
MFM> Examples:
MFM>
MFM> [Change to Color 38]
MFM> Hint=Change color to 38
MFM> A=^;^S7^S7^S8^38$^S0
MFM>
MFM> [Change to Color Yellow]
MFM> Hint=Change color to Yellow
MFM> A=^;^S7^S7^S8^yellow$^S0
MFM>
MFM> Note: If the color you specify is not found then the color will remain
MFM> unchanged.
I sent a wishlist item in a while back for the ability to
change custom colors through the menu system, so that
keyboard shortcuts could be programmed using strictly
menu keys, instead of requiring a mouse move that couldn't
be programmed. Dave G informed me that this would be included
in v11.08. My reason for asking for menu key access is to use
with the Gateway programmable keyboard. How is the above
accessible by menu keys alone? I've installed v11.08 and don't
see any ability to change custom colors without using the
mouse.
MFM>
MFM> Examples:
MFM>
MFM>
MFM>
MFM> unchanged.
mouse.
Steve Scott
