When I work on a lot of 3D models I go switch from plan view to one of the elevations from the view pull down menu. But when I do that the 2D menus, which don't work in 3D views, stays, and if I forget to change the menu to the 3D menu version, DataCAD jumps back to the plan view. It gets very annoying because I have to then get back into the elevation view. So it would be great if the menus changed for you. An even better idea would be to have all the commands work no matter if you are working in the plan view or any of the elevations.
Hello John:
This would be excellent!
