This is getting extremely annoying. Every time DCAD autosaves the program freezes up for about 10-20 seconds depending on the size of the file. I just sit there waggling my mouse around while the screen is frozen.
I'm not sure of the culprit, but it started after we switched over to a Win2003 server, although I suspect part of the problem is in DC11 not allowing me to autosave locally (C:\drive). The autosaves go to the location of the file (the network server) and since they are uncompressed this can often be a large file.
I used to never notice the backup, but this is horrendous. Shouldn't this process be in the background and low level as to not disrupt the work flow?
If anyone has a solution, I have an arm & a leg for you.
David L Mooney
