I recently removed RC24 and replaced it with the production version. When the production version requested the hardlock I inserted it into the USB port previously use for RC24. The application started fine, after awhile I received a waning notice that the key could not be found. If I remove the key and put it back the application would find it only to tell me later on 'key could not be found'.
Moving the key around to deference USB ports yielded the same results. I went to the web site and downloaded the latest hard key driver and installed it. But the results were the same intermittent problems with "key not found".
During the beta testing phase I never had a problem with the hardlock key.
Any ideas as to what to look for?
Vincent
