I seem to be losing the actual display of some entities in a xref with a clip cube with the clip turned on. If I have the clip turned off they show up. The entites in question are there but for some reason (bug?) they disappear when the CC is on??? There is no consistency in this though... Different entites at different times... File size seems not to matter...
It almost appears to me as though it is a display issue because of when you select the xref to put the new cube in, it dashed up all of the xref entities, and then when you add the clipping box and hit an ok, it appears that the dashed xref entites don't quite refresh themselves properly... Regen does nothing to fix it.
Anyone have any ideas???
Kent
Kent
