Hi all,
I have had a similar sort of problem today with one file.
I have tried purging the file to no avail.
I then tried exporting each individual layer to dwg separately and came a cropper with two layers. On further investigation I have managed to narrow the problem down to having a dragged and copied paratext entity on each of the layers.
That is, I have written a bit of paratext on the layer and then copied the text to a different location on that layer. This occured on two different layers.
What I have found is that if I deleted one of the pieces of paratext then that layer would export to dwg. This is the case with both the individual layers, but interestingly on the second layer I had to try it once and it wouldn't export, however if I deleted the alternative paratext leaving the paratext which was deleted on the first try it did work!!?? Make sense??
So I suspect it has something to do with copying of paratext.
I am going to send TechSupport the file for them to investigate.
Robert Penn
Melbourne Australia
Datacad User since version 5
Datacad 22.01.14.02
Windows 10 Pro (Desktop)
Windows 10 Home (Laptop)
