Good morning, two questions for ya chaps this morning. First, I am trying to merge the rendering toolbar into my existing 3D modeling toolbar. I can't seem to get the By Layer/Color Material buttons to work. I am using the codes listed on the extended codes list. The material editor and rendering prefs codes are working fine. Here are my codes.
Second question, is there a code can I use to duplicate the O2C viewer button from the rendering & viewer toolbars. Those buttons supports the feature where we can use the clipboard select to select specific entities and view just those entities in O2C. The only O2C code I have found is the 0243 ó and that will only display the whole drawing in O2C. Are these special internal toolbar buttons only? Thanks for any help as always.
Code: Select all
[Layer Material]
Hint=By Layer Material Assignments
Icon=MATBYLYR24
L=1032
[Color Material]
Hint=By Color Material Assignments
Icon=MATBYCLR24
L=1031
