Can I export a smartwall to dwg? I've tried, but not succeeded. Import/conversion into DataCad Lt 12 or AutoCad DWG TrueView 2009 shows all entities but the Smart ones.
Undoubtedly I'm the "dumb" entity.
Thanks for the help.
Joined
Fri Aug 29, 2008 5:05 pm
Hiya,
You probably have to Export 2D and/or 3D before doing the DWG export.
What version of v12 are you running?
Joined
Fri Feb 11, 2005 11:24 pm
Location
Maynard, MA, Eaarth
Hi Neil,
Thanks for the reply.
DataCad Lt 12 is the version I'm using.
So would that mean to do the following: Tools - Extract 2D/3D
Then export the level(s) that were extracted as the dwg file?
Thanks again.
Allan Stanley
Joined
Hi Neil,
I tried your suggestion and it worked. I appreciate your time and help with this matter.
Sincerely,
Allan Stanley
Joined
You're welcome Allan; I'm glad I could help.
Joined
Location
Maynard, MA, Eaarth
HandCrafted With and By SiteSplat ©SiteSplat 2013
