G'Day!
Okay, now I'm getting a better picture! Have you tried printing from DataCAD with a really small, simple drawing? (It may just be taking a long time for a big one -- how long are you waiting?)
Is there a setting in the printer control panel to select where the printing is processed? If so, it probably defaults to the printer, but it is very possible that processing it in the computer will be much faster.
Also, does the paper size selected in DataCAD match the paper loaded in the printer?
As you say; it
should work! Maybe on Monday (or actually Tuesday, since Monday is a federal holiday) we will hear from Mark Toce -- he'll probably know what to check. If you want to be sure that he sees it, you might e-mail him at
TechSupport@DataCAD.com.
IHTH
