I'm using Datacad v.10 i'm trying to import a .bmp file but it won't let me it says the "file name is too long" [/b]
juve wrote:I'm using Datacad v.10 i'm trying to import a .bmp file but it won't let me it says the "file name is too long" [/b]
The message refers not only to the name of the image, but also to the complete path to the folder in which it is located. For example, the path C:\Documents and Settings\User Name\My Documents\My Pictures\Client Name\Project Name\Image Files\Image.bmp would be too long. Move the image file to a folder that has a shorter path, such as C:\DataCAD\BMP and you will be able to insert it.
