jlmcougar wrote:I agree with the macro and sym mirror but I thought that it you drew an arc with 2-point, just as the arc is struck in the direction of the draw so would the arrow follow. Not the case. There just doesn't seem to be a way to draw an arc with the line type arrow going clockwise.
Here is a .dlt file for an Arrow linetype in the opposite direction of the standard DataCAD Arrow linetype. The arrow will point in a clockwise direction no matter how your arc/circle is drawn. The default spacing is 1". Just copy and paste the text into Notepad then save as filename.dlt to the Support files/linetype folder. I use ArrowCw.dlt for Arrow Clockwise, that way it appears right under the standard Arrow linetype. I wouldn't change the name or the original Arrow linetype for the sake of any previous drawings that may use it.
[Line Definition]
Segments=11
EndCorrection=1
Factor=32
Seg1=100.5 -5.55111512312578E-17
Seg2=0 -0.05
Seg3=-0.35 4.16333634234434E-17
Seg4=-2.77555756156289E-17 -0.1
Seg5=-0.149998561493102 0.149998561493102
Seg6=0.149998561493102 0.149998561493102
Seg7=-2.77555756156289E-17 -0.1
Seg8=0.35 -8.32667268468867E-17
Seg9=0 -0.05
Seg10=99.5 2.87701379608762E-6
Seg11=101 0
HTH
