Is there a way to draw lines at specific angles while using Dir. Dist.? I know you can use Rel. Polar, but doing mostly floor plans with right angles it really is faster fo me to use Dir. Dist.. Thanks.
-Redd
-Redd
Heinrich wrote:Is there a way to draw lines at specific angles while using Dir. Dist.? I know you can use Rel. Polar, but doing mostly floor plans with right angles it really is faster fo me to use Dir. Dist.. Thanks.
-Redd
MtnArch wrote:The great functionality about Dcad is that a few whack's (thanks, Jim Horecka for that euphanism!!) on the "Insert" key will get you to RelPolar, and another quick ones will get you back to DirDist. The best of both worlds!!!
HTH
Users browsing this forum: No registered users and 15 guests
