I am putting together a library of o2c objects created in some of the models I have done. My problem is when I insert the saved o2c object into the drawing, exploded or not, it gets inserted by the mid point of the Z height of the object. I moved the object to Z=0 and my Z was 0 when I saved it. How do I get it to insert at my z-base setting?
Dan
When you use File/Export/o2c to create an o2c object, DataCAD does not provide you with the opportunity to define an insertion point. It automatically sets the insertion point as the center of the X, Y and Z extents of the object. We would have to enhance the program to provide the ability to define an insertion point for the object.
If the sole purpose of creating these objects is to be able to insert them back into DataCAD, you might be better off saving them into a custom symbol library instead. One of the steps in saving a symbol is to define the insertion point.
