None of the suggestions for successfully using the Firefox 02c plugin worked, so I contacted Dr. Klaus Kremer at o2c. He sent me the following html code and it works great for both Firefox and IE. His code is red, I spliced in the rest of the code to get notification of the controls I wanted:
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
<BODY BGCOLOR="#000000" TEXT="#000000" LINK="#0000FF" VLINK="#800080" ALINK="#0F0000">
<div align="center">
<table border="0" cellpadding="4" cellspacing="4" style="border-collapse: collapse" width="100%" height="100%">
<tr>
<td width="100%" align="center" height="100%">
<p align="center" style="margin-top: 0; margin-bottom: 0">
<font face="Verdana, Arial" size="1" color="#FFFFFF">Shift+left button for Pan,
Ctrl+left button for Zoom, Right Click for settings.</font><br><br>
<script type="text/javascript"
src="http://www.o2c.de/utilities/o2c-utils.js"></script>
<script type="text/javascript">
o2cInsertObject('o2c_id1', '2.0.0.57', 640, 480,
'Phi="227.864700"; ' +
'Psi="39.359985"; ' +
'Zoom="0.903993"; ' +
'PanX="-0.224418"; ' +
'PanY="1.685330"; ' +
'ObjectURL="cubeSmith.o2c"');
</script>
</body></html>
Change the ObjectURL to your Object of course and to your location if not in the same folder.
He gave me a good tip on getting the desired opening appearance of your Object. Play your object by clicking on it's o2c file. Adjust it too how you want it with the spin, pan and zoom controls. Right click it and you will see that particular html is copied to the clipboard. Copy and paste the generated Phi, Psi, Zoom, and Pan information into your html code. Now that position will be the o2c Object starting position.
Long live o2c and DataCAD.
<html>
<tr>
</script>
</body></html>
