Not sure what the advantage is of using an attribute but required to use it because of cad standards. Is there a way to create a quick key for editing attributes rather than the multiple mouse clicks required by the software?
A couple ways.
Some, based on I think Josh Huggins thinking have modified our alt-key to edit text to first attempt a edit attribute.
H^170#^$^8#^S8^S2^F1^$^
\\ H- Change Text
this works good for 1 at a time.
Or you can use a Command Alias (or make it a Alt-Key also)
[sa]
comment=Change Symbol Attribute
alias=^170#^$^
This one, you can keep picking symbols without having to do the alt-key again.
