This is an
older wish but it's still kind of an important one. We can now override an individual associated dimension's Scale Type which is a super useful feature, but what we would like to see is a way to be able to set rounding on specific dimensions. In our office we try to always keep dimension rounding turned off to ensure that our drawings are as accurate as possible and to allow details with in the same drawing to be dimensioned with a high level of precision. Inevitably we have to dimension objects where we get a dimension that that math will give us a extreme fraction, site bearings or get sloppy drawings from consultants that we do not want to adjust the drawings but need to dimension. In these cases we need to allow these dimensions to be set to a rounding tolerance that is greater than that which we want to allow for the rest of our drawings. Hope this makes sense.
On a side note something that is kind of missing from the AssocDim Properties is probably being able to set the precision (32nds, 64ths etc.) of the dimension like we can via Change, Dim, Lock Scale.
(P.S. - The Change, DIM, Lock Scale menu title is incorrect, it's labeleded 'Text Style') Another little possible bug/wish is that we can't select the precisionon of a dimension if we try to Change, Dim, Lock Style, Inch/Frac.. It works correctly if we lock style to Arch.
Thanks for the ears
