It appears that the arc factor has changed with this update... I guess it jhelps your page load quicker, but the main problem I have now is as follows: We use the Architxt font with a 15 deg slant.... and now when you type the left margin is also slanted.... that does not look good... any ideas anyone!?
When you say that does not look good, do you mean how it displays/ prints, or just as a problem? Is it a alignment issue or a snapping issue? I think it could be a step towards better TTF support. I can see how this could be a tough to get use to for snapping, but it makes sense that the box would slant if there is a slant factor applied. Probably will need to just remember to snap to the bottom of your text.
Ah I see the problem now. Yeah that's defiantly a weird bug. Looks like Datacad picks the place to start the next line in reference to the top and bottom of the current line of text. I'll forward it to the bug reports forum.
As for the arc factor, that you can change it back, but maybe changes in precision to Datacad 11.08 need to have the values reset in order to accept the new format, and maybe there's a bigger/smaller differance now for the values, but thats just a big wild guess.
Users browsing this forum: Google [Bot] and 41 guests
