I'm finding that I cannot export to Sketchup - simply nothing happens. It's as if no command was selected at all and there is no skp file to be found. I made sure that I have the latest update. I also tried saving to SU v.7 as well as 8 - nothing. Purged, rebooted, tried files large and small, you name it - still nothing.
As a check, I tried a model that I created in the spring with Dcad15 and had exported to SU with no problems at that time. When I try to export that aec file to SU using Dcad16, nothing happens. So I'm fairly certain it isn't the drawing files themselves.
Any ideas anyone?
Thanks!
Melina
Any ideas anyone?
Thanks!
Melina
dcad user since v.5
