Please, I need to know ha to rotate a material after I save it. I used an image of wood I save from somewhere but even a rotate the image before, when I used it show in the original position. Can anybody tell me, please?
I do this before I used in Dcad, so I have both pictures, one vertical and other horizontal. When I load it to Dcad both are in same direction (horizontal).
Hmmm....the only other things that come to mind is to check the layer you are inserting the bitmap image is not locked or, if you have more than one version of DataCAD installed, that the directory/folder where you saved the rotated image to is the same you access when inserting the image. It should work. Did you open the rotated image in an image editor (Visual Image, Windows etc.) to see it shows as rotated?
I don't know what is wrong. I thing I do it the right way, but doesn't work. Yes I open the image like that, and is ok, one vertical and the other horizontal. It's make me crazy. Thanks for your help.
