Data Cad Pro V14.03.02.08 (PE)
Windows 7 Professional
Version 6.1.7601 Service pack 1 build 7601
Possibly have a corrupt file. This is the common scenario: Im working in the drawing / I do a standard plot/print set up (eg no multi layouts etc) / I return to the drawing after a plot preview / When I use "go to view" the file crashes. It is always when I use "go to view". Happens only on two files (so far) that I had open the day it all started. Also there are no ARF files, ARB, DRF etc created. So can't seem to rescue drawing file. I CAN open the file again, it just crashes after I follow that routine. Otherwise when I work in the drawing it behaves. I have done a layer set and loaded into a fresh drawing file. Something comes along with it because same thing happens: plot setup / return to file / go to view / crash. Currently I am doing another layer set and not including the views and will see what happens. Thought maybe it had to do with print driver, or datacad. Both driver and datacad work fine otherwise. Still wondering if I should re-install datacad and/or print driver.
Thanks for any insights. I really appreciate it.
Ben Eastman
Ben Eastman
BEN
