I noticed that if all the Snap settings are turned off (None), the warning message, "No Object Snap settings currently in effect" shows up in the message panel. Unfortunately, it STAYS there, so no other messages can dominate, such as information provided by the Identify function, unless all the checkboxes under Dynamic Snapping in the Program Preferences are also turned off. That's a lot of steps every time one might switch from None to "Some" Snaps. Is there a way to prevent this conflict and still have the warning message???
dcad user since v.5
