..and some enhancements to smart entities:
1. fix the issue with doors/windows coming loose from walls, (this is a big obstacle in using the smart entities for construction documentation drawings),
2. improved cleanups, including fixing the issue where different wall types that a mirrored, copied, rotated etc. and their end points coincide causing a wall(s) to shoot off into space,
3. allow trim-to function where a wall can be trimmed up/down to a selected slab, polygon, covered polyline, 3D line,
3. fix the issue when 2-line trim of curved wall and straight wall which often results in the curved wall changed its radius,
4. fix the issue in offsetting a curved wall which results in it changing to a straight wall,
5. improve curved walls creation and support for inserting doors/windows,
6. expand on the smart entity palette allowing more commercial options for doors, window, curtain walling etc.
7. add double doors where one door leaf is a different size than the other, (hotels, medical/hospital, function rooms etc.).
8. add the option to display the door handles in 2D as per DataCAD Plus,
9. add double, triple, (user option) sliding glass doors (highrise apartment sliders, commercial autosliders etc.), louvres, corner sliders without the mullion,
10. add smart balustrading, handrails, fencing,
11. add the option to display a dashed line (or user defined line) for cutouts, door/window heads, sills,
12. allow the smart walls with doors/windows/cutouts in to display a plan view at a user defined wall height so the same walls can be used for a reflected ceiling plan. This means if the floor plan is changed the RCP automatically changes to.
13. add smart elevation and section tags/views which link to the plan and section or elevation generated. Placing a 4-directional internal elevation tag would automatically link and generate 4 internal elevations in a room/space,
...and improve the speed DataCAD handles information. We can load a 200mb+ file in our render package and it is able to be moved around the screen effortlessly yet DataCAD jumps and jerks around or crashes with only modest entity selections. Even Visual Reality (1990's vintage) could handle large amounts of data easily so improving how DataCAD holds data and allows the user to navigate through a model would be welcome.
