Is there a way to manually select the object snapping type without having the snapping type on in the running object snap. Example; if I was drawing lines to an arc/circle and wanted to select tangent for one use, can I hit a series of keys to use the tangent object snapping for one use?
Arthur Wood
CADD Manager
EH Danson Associates
St. Johnbury, Vermont
There may be a way to set up a keyboard macro to do this, but other than that, I can't think of a way to do this. Leaving some snap settings, like Tangents, is not a problem, though, in my opinion.
In the next update 17.02, Dave has added a wonderful new enhancement to the Get X & Y context snapping menu that gives you access to all the available/appropriate snap features. In the example screenshot I have Tangents turned off in my Object Snap menu. I started a line, then I used Shift+Snap (middle mouse button for me), and it gives me all the available snapping options for that point.
If you have a subscription plan, you can get access to the latest beta release to test it out, or just wait for it's release. I am not sure if there is a target release date for 17.02 but would think it's getting close, but that's just my guess. I would also guess this will only be available for those with a subscription plan until v.18 is released.
Snappy New Menu
Thanks! - Josh Do. Or do not. There is no try. Josh's Digital Downloads is come back online soon. Stay tuned. (soon is a relative term)
