We are currently running ver 15.04.02.01 (PE) in our office. I know we need to update but right now the money just isn't there. Ran into a bug possibly and have never seen anything on the forum for this problem and I was wondering if maybe someone could recreate the problem with ver 17.
We have a plan file. in this file I created an xref layer. Inserted a self-xref on that layer. GTV link is on in the xref manager. Xclipped the xref for a part plan. Saved a GTV. Xclip the same self-xref for a second part plan in a different area. Saved a second GTV. Each GTV has 2 layers associated with them, the xref layer and a text layer.
I then went back to my 1st GTV, changed the layers I needed in the XR manager to create reflected clg plans, (just turned off misc layer and text), added a text layer and saved a GTV. Did the same thing for the 2nd GTV to create a 2nd reflected clg plan.
I then created an MSP sheet with a title block and the 2 part plans. Wanting to have the same layout for the reflected clg plans, I copied the sheet with the part plans to another sheet (in MSP) and was going to update the part plans to the reflected clg plans.
That is when I noticed that once I copied the part plans sheet to another sheet all the GTV links were broken for the part plans as well as the RCP's. The last xclip was the only one remembered. And the GTV link toggle was still on in the XRM. Very weird.
We had many part plans in this file and it took some time first to figure it out and then to fix it so I was hoping one of the DC experts will see if this is still the case in Ver 17. Many thanks for any help with this.
Dan
Dan
Dan Martens
NBF Architects
Rutland, Vermont
NBF Architects
Rutland, Vermont
