Welcome Jon!
First off, check what you have set up in Utility/Dimensions/Linear/Text Style. Check the size of your text and whether "Text Scale" is on or off (if this is off, your text size will be the height in-scale of the text - ie. for text that measures 1/8"h when plotted for a 1/4"=1' drawing it would be set for 6"; if it is ON your text size will be the final plotted height you want, or 1/8" instead of 6").
You should also check through each of the settings that are in Text Style, Dim Style, Arrow Style and Auto Style. When you have everything set the way you like it, pick "Styles" and save it with a unique name so that you can load it into any other drawing!
I hope this helps!
Highest Regards,
Alan T. Hendry, RA
