I like the new DataCAD configuration dialog in the v18.02.01.01 update! I am looking through it, and seeing several new things that used to take an edit in the DcadWIN.INI - thank you Dave!
I did not notice the option to show the current plot scale in the Status Area. Is this in the new configuration dialog, or is it the new default, or does it take a INI edit?
