I am creating a gable using the 3D vertical slab function. The object will be a gable separating work stations in a commercial project. At present the only way I can add a radius "fillet" to the corner of the vertical slab is by rendering the slab to a 2d image and then filleting the corner. I have many gables to do so being able to do this in 3D would be much better and faster. Perhaps someone has done this and can suggest a way to do it?
I've given up on slabs for the most part and stick with using polylines and tilting them up in place.
Hum. I'd like to try that. I'll see if I can figure out how to tilt them up....thanks Josh.
Oh and by the way did my pdf come through? Should I use jpegs instead as attachments to my posts?
PDF worked fine, had to download/open it but it worked. Glad to see we can attach PDFs now.
