When I go to an elevation and use the HIDE command Datacad shuts down stating ...Exception Violation in module DCLDwin win.EXE 00000000 ahs anyone else had this problem
similar experience: i had just added a front elevation layer to newly created drawing (copied from existing) and selected single line to draw and it immediately shut down with no explanation.
It is likely that there is one or more corrupt entities, and you may be able to correct that with the Purge function on the File menu.
