I create DWG files from my DCAD site plans all of the time to provide to the surveyor for preparing the "permit survey." Don't remember seeing the dimension issue I am now seeing. In DCAD, I hand pick which dimensions to change to Decimal and to 2 digits of accuracy using the Lock Scale function.
Below, I show what I see with the DCAD file and what I see in the Exported DWG file.
As can be seen, the 12' dimension did not retain its decimal style dimension and reverted to Architectural. The two dimensions at the bottom, retained their Decimal style dimensions. Don't know why all of the Decimal style dimensions are not retaining that style through the exporting process.
David Porter AIA
(DataCadder since v.2)
