For some reason the default text line spacing (Line: 1) is stacking text directly on top of the line below it without any space between. I haven't changed any settings that I am aware of so this is something of a mystery...anyone have similar issues (DCAD 19)
should add that when I check properties for text in question it says that the text is set to "text:line feed" - turn that off it corrects the issue but there is no way to do this prior to inserting the text into the drawing (as best as I can tell) ...is this an ini issue?
On the Misc tab of the Preferences dialog, uncheck these 2 options.
David A. Giesselman
Senior Vice President & CTO
DATACAD LLC
dave@datacad.com
DATACAD LLC
dave@datacad.com
Thanks for that tip Dave! That was driving me nuts since I installed 19 as well...especially with knock-out on,
Mark Rupsis
Rupsis Associates Architects. P.C.
Users browsing this forum: No registered users and 26 guests
