I noticed that the .DIS file I had in v18 didn't get copied to v19. It would be good as well to have the default Text Scale etc settings carried over.
Here are all the files and settings that are transferred during a new installation of DataCAD 19
(If you choose to transfer files and settings from the previous version that was found)
Fonts:
\DataCAD XX\Fonts
*.chr
*.shx
chr2shx.dat
Report Forms:
\DataCAD XX\Report Forms
*.frm
Toolbox Macros:
\DataCAD XX\Macros
*.dmx
*.dcx
*.dor (AEC Model Door Types)
*.win (AEC Model Window Types)
*.msg (Message files)
*.lbl (Label files)
*.str (3D Stairs Stair Types)
The following macros are not compatible with DataCAD 11 and later.
Estimator Link
ESTLINK.DCX
Layer Utility
LYRUTIL.DCX
Symbol Explode
SYMEXP.DCX
View Master
VIEWMAST.DCX
Support Files:
\DataCAD XX\Support Files
dcadwin.pat (Classic Hatch Patterns)
dcadwin.pat.ini
dcadwin.mcr (Keyboard Macros)
dcadwin.lin (Classic Line Types)
dcadwin.dca (Command-line Alias)
*.dmf (Material Files)
text.stl (Text Style (Obsolete))
wall.stl (Classic Wall Style)
*.tbl (DWG Color Mapping Tables)
*.ini (DWG Transfer Settings)
*.lit (Shader Light Settings)
dcadwintoolbars.gui (Toolbar GUI Settings)
dcadwindialogs.gui (Dialog GUI Settings)
ObjectViewer.gui (Object Viewer GUI Settings)
Dimension Styles:
DataCAD XX\Support Files\Dimension Styles
*.dimstyle
Color Palettes:
DataCAD XX\Support Files\Color Palettes
*.rgb
Program Defaults:
DataCAD XX\Support Files\Program Defaults
dcadwin.ang (Default Angles)
dcadwin.dec (Default Decimals)
dcadwin.dis (Default Distances)
dcadwin.scl (Default Scales)
Toolbars:
DataCAD XX\Support Files\Toolbars
*.* (All Files)
CST - Context-sensitive Toolbar
DTB - DataCAD Toolbar
PNG - Icon Bitmap
Hatch Patterns:
DataCAD XX\Support Files\Hatch Patterns
*.dhp
Line Types:
DataCAD XX\Support Files\Line Types
*.dlt
User Dictionary:
DataCAD XX\Support Files\Dictionaries
userdic.tlx
Pen Tables:
DataCAD XX\Support Files\Pen Tables
*.pen
*.dpf
Default Drawings:
DataCAD XX\Default Drawings (including sub-directories)
*.aec
Wall Types:
DataCAD XX\Support Files\Wall Types (including sub-directories)
*.wls
Door Types:
DataCAD XX\Support Files\Door Types (including sub-directories)
*.dor
Window types:
DataCAD XX\Support Files\Window Types (including sub-directories)
*.win
Text Styles:
DataCAD XX\Support Files\Text Styles (including sub-directories)
*.txtstyle
Plotter Settings:
DataCAD XX\Support Files\Plotter Settings (including sub-directories)
*.dps
Sun Shader:
DataCAD XX\Sun Shader\NX\Support Files
geogdata.ini
Note: These files will not be transferred if they are located outside of the DataCAD program folder.
